boxer пишет:а есть какие-нибудь пошаговые инструкции по реализации? я не очень дружу с линуксом...
Установить Node-red https://nodered.org/docs/hardware/raspberrypi (если установлен - пропустить этот шаг)pi@raspberrypi:/$ sudo apt-get install libavahi-compat-libdnssd-devpi@raspberrypi:/$ npm install node-red-contrib-homekitpi@raspberrypi:/$ npm install node-red-contrib-broadlinkpi@raspberrypi:/$ node-red-startВ браузере пройти по адресу IP_вашей_RPI:1880Из левой панельки с узлами вытянуть homekit и RM, соединить и настроить следуя подсказкам из панельки справаДобавить устройство в HomeKit на вашем IPhoneК примеру: (Меню > Import > Clipboard)
[{"id":"cf6fa652.064cc8","type":"homekit-service","z":"37e3d071.a4e02","accessory":"b450f54e.9eb068","name":"","serviceName":"Switch","x":470,"y":2500,"wires":[["8379b06.fc5e75"]]},{"id":"50c21b6c.7a6934","type":"RM","z":"37e3d071.a4e02","name":"","mydevice":"cad9f06.2b7641","action":"send","remote":"18","button":"102","x":710,"y":2500,"wires":[[]]},{"id":"8379b06.fc5e75","type":"switch","z":"37e3d071.a4e02","name":"","property":"payload.On","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"num"},{"t":"eq","v":"0","vt":"num"}],"checkall":"true","outputs":2,"x":589,"y":2499,"wires":[["50c21b6c.7a6934"],[]]},{"id":"b450f54e.9eb068","type":"homekit-accessory","z":"","accessoryName":"Кнопка","pinCode":"111-11-111","port":"","manufacturer":"Default Manufacturer","model":"Default Model","serialNo":"Default Serial Number","accessoryType":"8"},{"id":"cad9f06.2b7641","type":"rmdevice","z":"","folder":"/home/pi/Broadlink","mac":""}]
Если возникнут затруднения, можете написать мне на email.
